dougrainer
Dec 11, 2015Nomad
You should have multiple switches for your water pump. That means you have a small CONTROLLER for the pump itself. It is rare for the water pump fuse to blow. There is NO in line fuse on your water pump. There are 2 locations for the fuses on your Monaco. At that inside fuse panel and the odds are the water pump fuse is located in the outside LF storage in front of the LF tire on that LARGE fuse panel. THAT black cover panel will tell you what each fuse goes too. The odds are the pump controller is bad and is usually located in the outside water bay area on the wall behind the white panel. Doug
