Bucky1320's avatar
Bucky1320
Help with 1998 Harney Renegade DP
I have owned this rig for 6 months. I put new tires on it last fall. It is on a Magnum chassis with 4 air bags. 24,000 miles. Bilstiens I think original.
Rough ride and not as resistant to wind as I expected with a DP.
I can't find a pressure chart for the Hankooks. I have been running 90 to 95 in the 275/70r22.5's...load range H. That may be a bit high. I haven't weighed it, but placard says 8900 front and 17,000 rear. Placard says 85psi front and 80 rear for 265/75R's.
I may go down the road to get Koni shocks on it. But I figured I would start with the free stuff.
We do pull an enclosed race trailer with it, and the extra weight at the hitch does seem to make things a bit worse.
Anything right off the bat you can suggest? Corner weights aren't easy around here...but I may be able to get axle weights at a grain elevator possibly.
