Johnny_Dearborn's avatar
Jul 01, 2016
Help With Busted Sewage Pipe!
Driving from California to the East Coast. My alignment was off so I took it to an alignment shop and as I left the shop I bottomed out and busted my sewage holding tank pipe. So I fixed one problem and now I have another. It's the big 3 inch pipe and it's got a hairline fracture in it. Is there a way to repair it without taking it into the shop and having them replace the whole pipe? Is there some way to fix it from within the pipe? Some kind of repair glue or patch kit?
Thanks! John
  • That's what I was going to recommend: two part epoxy putty. It works like modeling clay and sets up like concrete. The shower p-trap in my TC has been fixed with that stuff for 10 years.
    BTW- Dolly Parton is "busted". Your pipe was broken! :B
  • Johnny Dearborn wrote:
    What does the primer do?
    Not much on the black ABS plastic, since it doesn't need primer.
  • It is just ABS with almost no pressure. Mix some ABS shavings in with ABS glue should work. JB Weld should do fine also. If you think the crack may continue just drill a 1/8" hole at each end before you slap on the JB. Worst case you can cut the pipe out later.
  • Some RV repair places have ABS plastic repair equipment and could probably fix crack permanently at a fair price, call around.
  • For any future reader with the problem, buy a Plasti-Mend ABS kit. I've used it more than once and it works great.
