CA_Traveler
Aug 05, 2022Explorer III
enblethen wrote:
GFCI receptacles have what is called a feed through feature. GFCI receptacle may work but nothing downstream. Only test is to pull it out and check output.
Enlighten me as I though the plug on the GFCI was directly connected to it's load terminals and not downstream of it's switch or coil.
A three light tester would help identify whether it is a broken wire or ?.
Downstream plugs on the GFCI which can help isolate the problem.
38,779 PostsLatest Activity: Jun 16, 2026
