Just want to run this by some of you, at the present time when I climb a (Hill or Mountain) I let the Allison do the changing or down shift as needed, if it don't down shift at 1400 RPM I will down sh...
My CAT didn't come with an EGT, but I can see how it would be useful information. Where is the probe normally installed - upstream or downstream of the turbo? or is the probe already there for the ECM?
Also - what about inlet air temp? With all the worry about plugged up CACs, I'm surprised that the air temp on the output side of the CAC isn't monitored as well.
I expect I'd get all of these from an engine monitor app on my tablet.
