daldelta's avatar
daldelta
No power climbing a hill from dead stop
Current Situation
I have a 98 HR Imperial 40' motorhome with a Cummins mechanical 6CTA8.3 @ 325hp. My problem is no power on a hill from a dead stop. --I live in Tennessee in the hills, and do to property constraints when I back my motorhome out of my pole building I have to crank the coach hard to the left once my front end clears the building, I am also going downhill as I back out. After I have backed up as far as I can, to get out of my driveway onto the main road my wheels need to be cranked hard the opposite direction and climb uphill from a dead stop. I hold my breath every time because now when I bury the throttle the motorhome does not want to move. The engine is flat and I have no boost. After a few tries and much anxiety, it usually very slowly starts to move and I am able to get out of my driveway onto the main road. Once I am on the road I climb hills with no issues and seem to have plenty of power, my only issue with power is in the position stated above.
History- The engine has 48K miles and the only engine repair has been replacing the turbo charger. I do my own maintenance (not a professional) and changed the turbo myself after I was told by a Cummins dealership that it needed replaced. I had to be towed from my driveway to Cummings because on that occasion I could not get the motorhome to go up the hill. Cummings changed the waste gate and said it is a temp fix to get me home. After I changed the turbo it did not seem to help much, but now slowly the motorhome climbs the hill. It’s probably only a matter of time before I will need to be towed again. What can I do to get the power needed to get up the hill from a dead stop? What should I check, waste gate adjustment, fuel pump etc.? I do have a slight exhaust manifold leak, and I have adjusted the valves a couple of times, maybe I did something wrong there. When I changed the turbo I added a boost gage, and recently have seen as much as 20 pounds going uphill moving down the road. From my first observation it seems the crossovers and hoses/fittings are Ok and do not seem to be the problem.
Thank you for your responses and help
Dave
