rgatijnet1
Apr 09, 2015Explorer III
As with any RV roof, it is a good idea to check the roof on a regular basis. With only one seam down the middle and the two joints at the front and rear caps, there is not much to check unless the Eternabond tape has been punctured. The roof itself never needs to be coated with any sealant since it is solid aluminum that is not going to crack. The aluminum roof also is not going to deteriorate because of sun damage.
38,776 PostsLatest Activity: May 15, 2026
