DSDP_Don
Jul 31, 2016Explorer
My Monaco was set up as Doug just explained, two outlets behind the refer, one inverted and one straight shore power. If you stuck your meter into the inverted outlet, you will often get funny reading like you did.
Monaco often used fuses for multiple tasks. You may not find a fuse labeled refer. It may be labeled something else and is sharing the duty. You need to take your volt meter and hit each fuse in the panel.
38,769 PostsLatest Activity: Apr 04, 2026
