dougrainer
Jul 31, 2016Nomad
This link takes you to the 366 page 2004 vacationer owners manual. See page 305 which shows the fuse and location for the refer. It is fuse number 5-67 and is a 5 amp ATC. Doug
PS, SAME fuse panel the Diesels use.
http://holidayrambler.com/partsandservice/manuals/2004_Vacationer.pdf
The distribution panel (12 Volt DC) is located inside the front roadside
compartment. Fuse assignments are listed on a fuse label attached to the
inside cover of the front distribution panel. When replacing fuses always
replace with the same size as listed for a particular location. Fuse sizes
shown are maximum fuse size allowable. Installing fuse sizes other than
those listed can cause electrical wiring to become overloaded and create
hazardous situations.
38,769 PostsLatest Activity: Mar 31, 2026
