dougrainer
Aug 01, 2016Nomad
10forty2 wrote:
Just for elimination's sake....is there possibly a glass fuse mounted on the circuit board behind the fridge?
And I'm also curious as to this mysterious fuse box in the basement compartment behind the driver's wheel. I have no such animal.....I DO have a chassis fuse panel on the firewall under the steering wheel inside the cockpit and the main distribution panel in the bedroom, but to date, have not found any other fuse panel.
Yes, there is a fuse on the refer control board. But, if you do NOT have 12 volts on that red wire, that fuse is not a concern. Also, that fuse board in the storage compartment, they can sometimes be easy to miss on Gas models. It may be on the pass side. They have that black plastic cover. Have you looked at the link I provided? Doug
38,769 PostsLatest Activity: Mar 31, 2026
