CA_Traveler
Mar 13, 2015Explorer III
While my Sani Con like others has it's features the big negative for me is the length of time it takes to empty the tanks. Plus running dry will damage the unit so you have to wait for each tank to empty. The discharge rate is 10GMP at most so the time is adding up. OK when you have a dump at your site but not OK for a CG dump with others waiting. Generally a PITA.
Plus when you disconnect the big hose you might have a mess. I have a twist on valve that remains attached to the Sani Con hose which helps.
