JimM68
Mar 13, 2015Explorer
Dennis, that rocks!!!
Here's mine.
Thay Y does indeed rotate, even if you have to unbolt it to do it.
Then just attach the sanicon hose.
But check and rebuild that pump, the PO most likely disconnected it for a reason.
I've always wondered how I'd bypass the sanicon on mine, cause the exit port is right below the Y, no way a 90 on the end would hit it. But rotating the Y 90 degrees sure would.
Here's mine.
