- D_E_BishopExplorer
hostage wrote:
I just simply go to a RV dump station or pick a park with sewer hook ups I really don't see the point of complicating a already complicated system
(that being the whole DPMH in general)
Suppose you are boondocking and no dump station availablr, what would you do? I have a sewerline clean out on the side of my house, it was installed for just that purpose. - jerrywilsonExplorerOnce I had to wait for a plumber all day. In the evening I got angry and did everything myself. Thank God web is full of different manuals. As a result, I installed InSinkErator Badger 5?P by myself which found in the review on http://bestsinkdisposal.com/ and saved own nerves
- theoldwizard1Explorer II
rv2go wrote:
I don't know how far it will pump the Black stuff, but before I used it, I connected my 75' 3/4" garden hose and pumped out several gallons of clean water from my gray tank. Holding the hose about waste high, I was surprised that it shot the water up at least 10' into the air.
This would be my concern unless you have a basement toilet. - fishingbob61ExplorerThank you rv2go, that is what I was looking for will make it today.
- azrvingExplorer
rv2go wrote:
Dennis12 wrote:
Every time i do this, my water taste like ****. Do you use your white hose???
I wash it out by running some bleach water thru it. :B
I was at a dump station and the guy ahead of me was walking around his rig and finally asked me if I had a hose with me so he could fill his fresh and move on. I said all I have is my dirty green hose that I only use for dumping. He said that's ok. I said but I stick it in my blue tote and dump hose etc. He said that's ok and stuck it in his fresh fill. This was also a dump only spot with no designated fresh fill. - hostageExplorerI just simply go to a RV dump station or pick a park with sewer hook ups I really don't see the point of complicating a already complicated system
(that being the whole DPMH in general) - rv2goExplorer II
I wash it out by running some bleach water thru it. :B - Dennis12ExplorerEvery time i do this, my water taste like ****. Do you use your white hose???
- rv2goExplorer II
coolmom42 wrote:
rv2go wrote:
I use one. I modified this one to my own ideas.
RV Macerator Pump
The gray flow thru. Pump the black as needed. 75 feet thru a 3/4 inch hose. Works like a charm. No worry of overheating the 12 volt pumps.
I know this is in the class A forum, but it's applicable to any RV with holding tanks. It's a good idea.
I can't figure out where the pumping power comes from, to have any lift. Is it just the centrifugal force generated by the garbage disposal?
I also have a 12 volt macerator pump and it will not pump as high. - coolmom42Explorer II
RV Macerator Pump
38,738 PostsLatest Activity: Jul 26, 2025
