Neil, if you look on the right wall (door open and higher than the MH) you will see my sprinkler system. Living on the lake we have 120 psi city water which I'm feeding into four 155 degree sprinkler heads. Used CPVC pipe wrapped in alum tape and before I replaced my NoCool firebomb I used a fifth head on a hose that I could put behind the unit, not just outside the vent. I rarely leave the refer on when in the MH bay, even now that I have a Amish unit. I have two remote sounding smoke alarms in the MH bay. The single car garage for the DW's car has two heads in there and one remote sounding alarm. I have 6+ fire extinguishers in the house and 4 in the MH plus one in every vehicle... actually it's 5 including the auto system in the vent for the MH refer. I have a 100' 3/4" water hose beside the front entrance with an adjustable spray head that will only be used to hook to the 120 psi frost proof hydrant in case of fire. This summer I'm planning on putting 4 rainbirds on my roof in case of a fire in the USFS next to us if forced to evacuate..
Did I mention I might be paranoid about fire?
