jwjkswanson's avatar
jwjkswanson
Hopefully just a blown fuse - Indicator lights not working
As we were doing a final check on everything prior to our next trip coming up we noticed that some, but not all, of the lights on lighting panel above the stove were not working.
Here is where we stand.
Hood light - is fine
Water pump indicator light - is fine.
Water heater indicator light - no good
LP gas light - no good
Fresh water indicator light - no good
Black tank indicator light - no good.
Gray water indicator light - no good.
Main Battery indicator light - is fine
Aux battery indicator light - no good
We are hoping it might just be a fuse and if so, where the heck would this fuse box be located.
Any help is much appreciated. Otherwise off to the repair shop.
Thank you.
  • Are you saying the indicator light does not illuminate or the actual appliance does not work? If the appliance(s) works it is just the light in the switch. Easy to replace yourself.
  • Make and model of rig would help.
    Normally the control panel is fed from the 12 volt DC distribution panel located adjacent to the 120 volt AC breakers behind a small dead front.
    Some also have a fuse behind the indicators on the circuit board.
