ACZL's avatar
ACZL
Gear indicator blank
This past w/e, noticed the gear indicator is blank. Shifts normal, just don't know which gear your in. Is there a fuse for this? Truck in sig.
  • Happy to report that the "+" worked!!!. THANKS AGAIN folks!!!
  • ACZL wrote:
    Will try the "+" later on way to work. Thanks.
    That should do it.
    That solved the mystery of my disappearing gear indicator numbers for me and our 2016 F-150.
    With all the new electronics on my 2016 F-150 Lariat compared to our former 2009 XLT, it took me quite a while to learn how to "fly" it.
  • Will try the "+" later on way to work. Thanks.
  • Is there an option in your settings to show gear indicator? I know in many of the FCA products you have the option on what you see for the gear selection. But that is with the electric shifter and I think you have the manual selector.
  • The indicator on our 2015 isn't showing unless you push the down shift button on the gearshift stick as if you are down shifting .
