colonelcorto's avatar
colonelcorto
Hot Transmission, what can I do?
What I have: 1996 Fleetwood Southwind 35LS, 460EFI, E4OD, Banks headers, Transcommand, US Gears Dual Range (under/direct), Dana series 80 5.13, trans temp gage, 96k miles, 19,800 Lbs fully loaded (includes all passengers).
The E4OD was rebuilt a couple years ago by the previous owner, he burned it up while towing his car on a car hauler. I am sure he was over the 23,500 Lbs max GCVW for this coach. Also, I doubt he understood how to use the auxiliary transmission. He had the E4OD rebuilt by a shop out east and they also replaced the radiator, added the trans temp gage, and possibly installed the auxiliary trans cooler. This was about 6k miles ago. When I run on flat ground the gage reads at the top of the normal range (about 200 F). When I ascend mountains (plenty around Las Vegas where we live) it is in the 220 to 240 range. We don't tow a car and I can ascend the mountains easily enough by locking out OD and climbing in 3rd (low range on the US Gears when they are really steep) with only a few down shifts to 2nd. I can maintain 40 to 50 MPH at using this method but at the above mentioned temp.
The charts I have read suggest that I'll only get 20k - 40k out of the transmission at these temps. What is the best way to get them down? Can I mount a DC fan in the front of the cooler with a switch on the dash? Should I install a larger cooler (I have gobs of room)? Or will slowing down on the ascents solve the issue? I am sure that this summer's 100F+ temps will compound the problem.
If I can figure out how to upload pics I will post them. Thanks!
