lakegirl11 wrote:
yes i know where the outside access door is but you cant get to any of the plumbing from there it is on the inside some where i just called fleetwood tech line and it is in the rear closet somwhere
There should be access to your bypass valves for winterizing. Usually there is a valve on the inlet that can be shut off, and a valve between the inlet and outlet that can be opened for bypass. The small pipe between the inlet and outlet should lead you to the outlet pipe.
If you put "hot water tank rv check valves" there is a ton of information and images about the problems with them.
I had a look at pictures, beautiful coach, and now I wonder whether access to your valves might come from within the right side of the engine compartment? Or from the storage compartment? It would appear that the lines to the bathroom would go under the bedroom floor to the bathroom.
