tiffinboy wrote:
etchison wrote:
I run gen and engine first of month,for an hour, the next day I found all batteries discharged ,never has happened before .
Any suggestions -?
How to trouble shoot ?
Always hooked up to shore power.
charger/inverter gone bad?
Thanks for your help.
etchison
which batterys? engine or house or all?? how did u find them dead?
chassis battyery,s are usually not charged through the converter
need a little more info to give educated opinion
note don't leave SP on when running the generator or the enginealso on a side
"Don't leave SP on"
WHY???? There is nothing wrong with doing that. That is why they have Transfer switches. The Chassis system will not cause any problem also. If you think so, then explain why you think so. Doug
