Mr_Mark1
Aug 09, 2014Explorer
Mtofell1, we have both air leveling and hydraulic jacks. I will usually level on the air bags if the surface is dirt or gravel. I'll use the hydraulic jacks on concrete or asphalt (if allowed).
Honestly, we get a little movement from both. I could not tell you which system we are using if I was blind-folded. They feel the same.
When the washer goes into a final 1,200 rpm spin, the coach will vibrate a little. So, I would give ours a 7 but the movement is very minimal. I'm not bothered by it.
Our new coach will have air only leveling which is what I would prefer if I only had one choice.
Good luck,
MM.
Good luck,
MM.
38,766 PostsLatest Activity: Jan 10, 2026
