Sully2 wrote:
Jagtech wrote:
There seems to be a misunderstanding about Cab Fresh. My carton says nothing about repelling mice, just that it neutralizes / eliminates mouse-related odors. The critters built a nest right next to a packet of it in my rig.
Irish Spring soap is a favorite of mice around here, they ate 1-1/2 bars of it before we discovered them. Found chunks of it in their nests.
Dryer sheets really do work for removing bugs, but mice use them for nesting material.
If you have no mice in your RV, then quite simply, there is no way for them to get in.
Only thing I found to work is a snap trap under each wheel, checked daily. They get into the rig by climbing up the wheel initially, so I get them before they get that far. So far 100% success with this method.
Read the box a little closer..??:S
Earth Kind Fresh Cab Botanical Rodent Repellent
First and only EPA registered for indoor use natural rodent repellent that uses scent to keep rodents out. No poisons means it is safe around humans, pets and food prep. Proven effective through EPA approved lab testing. Repels rodents for at least 30 days.
I guess the product is different in Canada... only indicates that it contains "Scent Pouches" to eliminate odors.
