- ron_dittmerExplorer III
j-d wrote:
Tell you what really helps: Heavy Duty Front and Rear Sway Bars! They improve handling on the road, but that extra roll stiffness shows up big time on the campsite. There are two major brands: Roadmaster and Hellwig. They are the SAME Steel and the SAME specs. Both use hard poly bushings. Difference is you can buy Hellwig for about half the price of Roadmaster.Cousin_Eddie93 wrote:
I am in full agreement with these two comments. The solution is best addressed by replacing the original/stock front and rear stabilizer bars with heavy duty versions (also referred to as anti-sway or sway bars) which greatly improve the handling of the rig when driving as well as stabilizing the rig when parked. You can perform THIS SIMPLE TEST to determine if your rig will benefit from heavy duty front and rear stabilizers bars. If so, I'd surely go with the Hellwig brand to save some serious money.
.....the Hellwig sway stablizers make the rig nearly unshakable, even when cleaning the pipes with DW.
If you are determined to bolt-on scissor jacks near the rear of your class C frame, be careful they don't hang down so far that they get damaged when pulling out of gas stations and such where the road has a big dip in it. - RE_ToddExplorerI use my hydraulic jacks!
- klutchdustExplorer II
Claybe wrote:
klutchdust wrote:
I camp in the desert, on the dry lake bed especially, and the stabilizers make a huge difference when the wind kicks up. Last trip I put my slides in because of the wind.
What kind of stabilizers do you have?
Hydraulic, operates from a box mounted next to the drivers seat. original owner had them installed as the coach didn't come with any. I use them even on level ground. - ClaybeExplorer
What kind of stabilizers do you have? - klutchdustExplorer III camp in the desert, on the dry lake bed especially, and the stabilizers make a huge difference when the wind kicks up. Last trip I put my slides in because of the wind.
- MacZuluExplorerI guess I should get my suspension checked out, I found my unit rocks quite a bit moving about. Rolling over in bed can even be felt, I'm about 210lbs. The rv seems to handle well on the highway so far, I've only done about 1000 miles. Been full and empty, driving at 50 full, and 55 empty. So I hadn't suspected it may be big contributor to body movement when camped.
So I first bought two 24" 2 1/2 T scissor jacks for the back, and it was alot better. Since then, I now have two 17" 6 T bottle jacks for the front end. Still enough rocking we wanted to stabilize the front. I just the bottle jacks so I haven't tried them, I only bought the high capacity because they were on sale. They're not for leveling, just stabilizing. We will try them in mid July for 7 nights. - ClaybeExplorerMan it would be awesome to have automatic levelers as I think those would level and stabilize the rig. That would be on the top of my list for the next rig. I feel like ours moves quite a bit and I wish it were more stable. I have the front sway bar, but not the rear. Maybe I need to get 4 scissor jacks and weld in plates to stabilize the rig. Just another MOD that sounds fun!
- Maestro402Explorer
DrewE wrote:
Maestro402 wrote:
I'm glad I searched for this topic. Last weekend my family bought our first RV a Class C. We didn't opt to spend the extra money for the auto leveling feature. We instead decided we'd just use the blocks.
I was looking at scissor jacks and what not for ideas to stabilize. Sounds like it might be best to just try w/o anything first. Ya'll Agree?
Along those same lines. Is it a good idea to buy the slide supports or step support? I guess my concern from a mechanical standpoint is that if I don't stabilize the main chassis well then putting slide support in is pointless if not dangerous to slide rods.
Thanks
Definitely try without any stabilizers. It's generally easier and cheaper to not add stuff than to add stuff, and when the stuff is unneeded, it's wasted effort and money.
If your slide or steps required extra support, surely the factory would have supplied the extra supports gizmos with the RV as standard equipment. Any maker that sold an RV where the very basic features are entirely unusable by design would not last long, I suspect.
I don't use any supports on my steps. I don't have any slides to worry about supporting or not, which makes that decision very simple.
We are going camping this weekend. I'm just going to give it a go as is. I'd much rather not ahve to buy the extra equipment. I'd rather spend it on camping gear. ;-) - DrewEExplorer III
Thanks
I don't use any supports on my steps. I don't have any slides to worry about supporting or not, which makes that decision very simple. - Maestro402ExplorerI'm glad I searched for this topic. Last weekend my family bought our first RV a Class C. We didn't opt to spend the extra money for the auto leveling feature. We instead decided we'd just use the blocks.
Thanks
38,769 PostsLatest Activity: Apr 03, 2026
