othertonka
Apr 16, 2015Explorer
My procedure for power gear jacks is to first set up your MH with a set of Hoppy Calibrated levels, first leveling the MH with a long carpenters level front to back and side to side. Then fasten the hoppy's to the MH so they are indicating perfectly level, one level indicating front to rear, mine is inside on the drivers side wall where I can see it from the drivers seat, and the second level somewhere indicating side to side, either on the dash or other side to side suitable surface. Fasten them so they read level. Now to use them park in your site, look at the front to rear level and determine whether which end is the lowest, say for example the front end is low. Then operate the front jacks (Low end) and raise the front just until the level bubble is one half bubble past level, stop, now operate the rear jacks until the level bubble just comes back to level, stop, you are now level front to back. now determine which side is low and operate the rear low side jack (Power gear has that feature) until the side to side level bubble comes back to the middle level position. You are now level side to side. stop and turn the switch OFF. done. Of course this is a procedure to use on pretty level sites. if the site is way off level, you might have to use boards under the low end tires to get it a little closer to level before using the jacks. The calibrated level bubbles show how far out of level you are in inches. for example the front could be 2 inches out of level and the bubble will indicate that. This gives you an idea if you can level the MH in that position with out running out of jack extension before you actually start the job. By doing the low end first you usually end up with the jacks actually doing some lifting and not just being extended and running out of lift. I use pads under the jacks for soft spots to increase the pad surface size.
Calibrated levels
Calibrated levels
