Rlaubert's avatar
Rlaubert
How do you use hydaulic levelers?
I have a 2007 Safari Simba with Power Gear Levelers. I am still new to the Class A world and have been on the road about 9 months. I cannot seem to keep the RV from rocking. I have the plastic blocks under the levelers stacked about halfway to the leveler pad on top of a wood base, that doesn't seem to help, I have tried without the wood and plastic blocks and that doesn't help.
Seems to get worse a day or so after set up. I do not notice the levelers retracting. I did notice once after about a week to 10 days that they did seem to retract a little and I leveled the rig again. But the moving returned.
No documentation on how to level, so I figured first step is make sure I am doing it right and second step is to see what the experts say.
Educate me please.
  • X2 never used pads under jacks, they are built in so to speak.
  • janstey wrote:
    It stays sturdy until we retract and leave.
    as do ours. unless the ground is soft from rain we don't use any pads under the jacks.
  • Fluid levels are good. Had a leveler replaced in Dec and had the shop drain and refill the system at that time. I check the fluids each time we pack up prior to moving (full timers).
  • Check your fluid level. If the fluid is low, the jack could still extract but might not provide much strength.
  • Ok, that is the same thing I do. Does yours seem to retract or does the rig stay sturdy during the time you are using it?
  • I have PG levelers and in most cases I set the parking brake, leave engine running, then power on the leveler controller in the cockpit, and once it becomes ready I press the auto button. It will auto level for me and stays put until I retract. In rare occasions where I worry about the system taking my wheels off the ground, I press the manual button, start with the fronts, then follow up with the rear until level.
