- rk911Explorer
PastorCharlie wrote:
If it is only the outside rubber weather cover on the cable cracked cover the cable's bad area with Dicor caulk and that will reseal it. The cable has a wire shield that will prevent the cable from actually breaking into and protect it from signal interference.
yahbut the crack in the outer covering will let moisture in and if the crack has been there for any length of time the coax may have been saturated with water. cable is cheap so if at all possible i'd replace that section. - PastorCharlieExplorerIf it is only the outside rubber weather cover on the cable cracked cover the cable's bad area with Dicor caulk and that will reseal it. The cable has a wire shield that will prevent the cable from actually breaking into and protect it from signal interference.
- powderman426ExplorerWhile repairing my roof, I saw that mine not only had a barrel connector, but the cable was stapled in place. I imagine it would be very difficult to replace. Bummer.
- MacGyver612ExplorerCoax seems to be one piece did not pull up due to we have to bring back for dealer to clean roof and reseal openings. When we get back I will pull up a little and see if coupler below antenna mount.It would be nice if that were the case, one can only hope.
Thanx - rk911Explorer
MacGyver612 wrote:
The antenna coax is cracked at the outside on the motorhome we just bought. 2002 Itasca Suncruiser. How hard is it to replace and what kind works best?
Winegard crank up type.
Thanx
Greg
on our 2000 suncreuiser there is a connector on the roof. you'll need about a 6-8 foot run (measure the old coax before buying the new) of RG-6 coax (75-ohm) with connectors on both ends. if your roof is like mine you'll need to peel away the silicone protectorant off of the roof connector and possibly the connector at the antenna end. unscrew the cable connectors from the roof and antenna, replace with the new cable and seal with silicone. - MacGyver612Explorerwhen I get the time I will find inside end and try til shack and listen to see if moving in ceiling. I hate to try to start to pull in a new one only to find that unseen clamp or.. in the way and can't pull back. I might at least do a new piece from crack to antenna for the time being and shrink tube connectors.
Oh the fun..
At least it still works, for now. - Dale_TravelingExplorer IINo telling how diffacult. The problem you will run into is getting to all the cable ties and wire clamps it you are going to replace the entire lenght. Best would be to cut out as much as you can and add a new lenght from that point forward. Don't forget to add enough cable so you can still rotate and raise/lower the antenna.
RG-6 is a good choice for cable. - MacGyver612ExplorerCrack is just a few inches from mount where it comes through antenna plate.
- MacGyver612ExplorerI have not pulled too much yet. Very brittle outside. may be splice outside and shrink tube it. TV is roof mounted. I am hoping that there are not cable ties in the head liner holding in place.
- Johno02ExplorerDepends. How is it fed through the roof, is there any slack, how is it routed inside. All rigs are different. Can you just trim the cable and replace the connector?? Is TV on dash or roof?? Where is cable power box located??
38,766 PostsLatest Activity: Jan 10, 2026
