eyeteeth
Jul 30, 2016Explorer II
Thanks for the quick responses.
I'll check into the cable. I will more than likely bypass the cruise control. I had a custom one made a while back by Southern Speedometer but it didn't quite fit right, and eventually broke.
"Over the years, I've seen two cases where the thermostat was installed upside down. The "wax" capsule, usually copper colored, needs to go down, into the coolant."
- I'm going to assume the current thermostat is installed correctly as it would only fit/work one way, with the skirt facing down.
"Your fan belt may be slipping at higher RPMs."
- Felt tight when we checked
"Some high performance water pumps have more vanes ... if I recall correctly, eight vanes versus standard six."
- Not sure I'm up to taking it apart.....
"If your fan has a clutch, the clutch may be malfunctioning."
- The clutch is relatively new as well. Seems to be functioning properly. The fan is turning when the engine is hot...
"Is your lower radiator hose in good shape? Suction at higher RPMs may be causing an old/soft hose to collapse, restricting coolant flow."
- That might be a possibility, This too is fairly new. I replaced it a few years back when I had the radiator recored due to leaks. However.. it does seem a little 'soft' to the squeeze. I'm sure it gets worse as the temperature rises. Perhaps a correct part number for this part. I had to adapt a lower hose before. Found something close and cut it to fit.
"Conversely, a partially blocked upper hose could allow enough flow at low RPMs but not enough at higher RPMs."
-Upper hose is good.
"Make sure the radiator cap fits properly and has the right pressure rating. A new cap costs less than $10 and is cheap insurance. (I often replace them just to be sure.)"
-I knew I forgot something at the store earlier today. Perhaps another trip is order. As the RV is not here. What pressure cap do I need? I feel like I bought one of those a while back as well.
"Does your radiator steadily lose coolant? A radiator without an overflow recover tank will have some air space at the top, with the air acting as a pressure cushion. However, the core should remain completely immersed."
-No. New core a couple years back. Has a recovery tank... although I was going to check to make sure there was sufficient coolant in the recovery tank.
"Finally, your engine temp sensor or gauge may be giving incorrect readings."
- I hit it with one of our racing laser temp guns.... its definitely hot.
Thanks for the checklist.
