Griff_in_Fairba
May 23, 2017Explorer III
VintageMopar wrote:
Looks like an aftermarket high current solenoid next to the overflow bottle. The drivers side loose wire would be supply, center terminal is control (12 volts to it and it connects the 2 big terminals together. Follow the pass side wire and see what device is on the other end.
I agree, it doesn't look like the OEM solenoids typically found on these older Dodge motorhomes, as well as other Mopar vehicles.
No need to worry about the solenoid itself ... as long as it does the job, you're good to go. (Unless you're a "return to OEM" freak like me.)
Listen to VintageMopar ... he may very well know more than Leeann and me.
