Griff_in_Fairba
Jun 23, 2017Explorer III
eyeteeth wrote:
I replaced the inverter/charger with a 'modern' unit last spring. The original unit, although ahead of its time... was still archaic. This purports to have a maintenance kind of trickle mode, as well 'cycling' the voltage every so many hours to help keep it from getting sedentary...
Electrically the house has been SO much happier since I installed it. If I knew it was going to be as easy as it was, I would have done it long ago.
I think I recall you mentioning the new power supply/charger. If it's the brand Leeann mentioned (or equivalent), you're probably good.
However, as TreeSeeker mentioned, it probably only charges/maintains the coach battery, unless the SLI and coach batteries are "paired."
Using a single charger/maintainer on paired batteries isn't a good idea. It may "sense" the level of charge in one of the batteries and under- or over-charge the other battery.
