Maya_215
Jul 12, 2017Explorer
Ok so I had gave up on the refrigerator the info you gave me was great Leeann I checked all my sources that were in the manuals and I still had no luck so I decided to give it a brake I still had to fix the fuel gauge it has never worked since I got it so I started take out the old one when I realized that the part I saw on the auto store websites was not what I had this fuel sending unit has three hoses running to it with the arm and float all in one also the tank top screwed off, there were no screws as what I saw online so I decided to clean the wire end and the ground wire up I then took the fuel sender out, well as I took it out I immediately found the problem the float for the sender was floating around inside the tank so I fished it out and put it back on making sure it was tight I tested it by putting it in a big rubber tote/storage bin of gas that I pumped out, having my daughter turn the key to the on position and moving the float up and down slowly and bam problem solved the gauge is now reading correctly then my daughter said dad I here this clicking sound almost sounds like are boiler when it lights up, I told here I thought she was playing with one her little toys but I heard it to,and well I be **** the darn fridge was working it was trying light up I went inside and the eyebrow was on man I have a lot to learn I have no idea how this is hooked up why does it only come on when the key is in the on position also there is like a relay that comes from the second dairy battery from the ground wire it's making a cling noise every few minutes this never happened before I messed with the tank not sure but any help would be great thanks
