Maya_215
Jul 12, 2017Explorer
Ok so I'm out here now Messing with the rv fridge so I took out my second battery from the little compartment it goes in and hooked up the positive to the positive and same with negative and nothing happened so I then tried to hook it back up the way it was I started with the black wire first and when I hooked it up the thing came on before I could hook up the positive (note this is with the ignition in the on position) so I turned the rv off and hooked my positive to the negative that's on the fridge and the thing came on I'm really confused there the tab says the left side is positive and the right side is negative not sure at all why this is any thoughts, also that relay stoped pinging or clicking I would say maybe I was over loading it by hooking up the ground wire instead of the power and I only did this because the wire going in was black and the other one was white
