Griff_in_Fairba
Oct 23, 2017Explorer III
Here's a link to a .pdf version of the instructions image Eric posted. It's essentially the same as what Eric posted and includes a wiring diagram.
Note that the wiring diagram shows a two connector ballast resistor. Also note that the diagram shows the fifth ICM connector (green wire) is not used. I believe the fifth connector is for the other side of four connector ballast resistors. (Google extensively to make sure this belief is correct ... I could be wrong.)
DO NOT rely on the 10.8 volts I stated in a previous post I made. I obviously screwed up my calculations.
Instead, rely on the 7 to 9 volts stated in the .pdf link (above) and the instructions image Eric posted.
