Griff_in_Fairba
Mar 18, 2018Explorer III
After posting my previous comments, I did some checking. (I googled 'painting propane tanks')
Apparently, there's nothing preventing you from painting your tank. There are, however, some specific guidelines.
-- Use light colored or reflective paint. Dark paint will absorb sunlight, possibly raising tank temperature to dangerous levels.
-- Info stamped into valve guard or base rings must remain visible and readable.
-- Remove rust and loose paint manually.
-- Do not use harsh chemicals or abrasives that could compromise tank integrity. Do not use rust converters, rust removers, sandblasting, or aggressive sanding. (In addition to other difficulties, I would not use one of my electrolytic rust and paint removal tanks.)
-- Clean tank with soap and water, rinse with clean water, and allow to dry thoroughly before painting. (As always, I recommend dish soap ... water should be, at most, lukewarm.)
-- Prime before painting unless you use self-priming paint.
-- Do not conceal rust pitting or anything that indicates possible tank integrity compromise.
There appears to be paints specifically marketed for painting propane tanks. I didn't research further to determine if these are indeed special paints or this is merely a marketing tactic.
Removal of surface rust only is acceptable. Any signs of rust pitting (or other damage) means you should remove the tank from service due to safety concerns.
38,782 PostsLatest Activity: Sep 02, 2026
