JoninFountain
Apr 17, 2018Explorer
Ballenxj wrote:JoninFountain wrote:
Vacuum doesnt seem to be the issue, might be missing something but checked connections, egr solenoid maybe, dont know when its supposed to kick off.
fuel filter changed, cleaned out the top half of the carb and jets are cleared, float, pump working fine.
We played the timing and advanced it a little and it hums nicely, Driving nice with power.
its at low speed with a load, or when Its first shifted into gear it can stall, I can nurse it thru forward to reverse with a little pedal play, and coax it into not stalling. when we close the choke a bit it runs wonderful but wide open it has the stall issue when put under load, again I can nurse it thru but shouldnt have to.
fuel/air seems to be an issue? back to research
How old or fresh is your engine? Have you checked the timing chain?
Timing is good. Original engine. There was no issue prior to the non use time.
38,782 PostsLatest Activity: Sep 02, 2026
