Griff_in_Fairba
Apr 18, 2018Explorer III
StingrayL82 wrote:
Just a thought for you, Eric....if you're looking for a way to return the fuel to the tank, and the carb doesn't provide for that, get a fuel filter that has a single inlet and dual outlet, like the Jeep used. The top outlet is used for the return. Jeep Fuel Filter
Hmmm ... I'm intrigued. I may buy one to experiment with.
Low pressure fuel systems (mostly engine driven pumps) don't usually need a return line. (Float needle valves are usually enough to resist fuel line pressure in low pressure systems.)
One of the problems with in-tank and inline fuel pumps (close to the tank) is how to get the electric pumps turned off in an accident. (Pusher pumps, versus suckers, are almost always better.)
At CarQuest, I often cautioned customers buying aftermarket electric inline fuel pumps. Especially if they appeared hellbent on a "bigger is better" approach.
The filter's return line may partially alleviate fire risk. Return line won't do much for a fuel line fracture or break but there is a potential for minimizing risk.
38,782 PostsLatest Activity: Sep 02, 2026
