Fbx-Ak
Apr 29, 2018Explorer
Eric Hysteric wrote:The fuel injection is much more responsive and meters gas exactly as needed. Computer controlled and adjustable. No unburnt gas getting into the cylinders.
Fbx-Ak, Holley Sniper fuel injection. How cool is that! What is your experience? Before and after, if you had a comparision between the carburetor and injection.
It requires a high-pressure fuel pump and a return line to one of the tanks. That means that if you are running off the non-return tank, it has the potential to overfill the return tank. So you have to watch your gauges to be sure that doesn't happen. We can now use an auto-start to remotely start it. You don't have to be sitting in the vehicle pumping the gas pedal to start it on a cold morning.
We have had a minor problem with gas starvation at high temperature under load, as in going up a long hill at high speed. It is probably an issue of the fuel pump not keeping up with volume needed. Perhaps a lighter foot would help.
38,782 PostsLatest Activity: Sep 02, 2026
