DRTDEVL
May 23, 2018Explorer
Here's a quick question... Anyone have a 79+ Chassis? The A/C setup is different in the 79 and later chassis than the older ones. My grandfather did not believe in AC, and only used the Winnie on the Pacific Coast. He removed everything under the hood, and nobody was able to locate it after his passing. I know it was a single-row pulley set and would have used a model RV2 compressor, but I need to see where everything hooks up... the evaporator is separate from the heater system (directly behind the center of the dash) with different ducts and a separate fan control on the same bezel as the heat/defrost. I have no idea where to source the manifold lines, where to mount the receiver/drier, if its an orifice tube or expansion valve system (but I can disassemble the dash to find that out), or the bracketry to mount anything... but I am pretty resourceful with retrofitting similar parts from junk vehicles. I can adapt just about any condenser based upon the fitting sizes, the space available, and the ability to put the largest possible condenser in the space (need more cooling on R134a than on R12).
Anyone have one and some pics of how everything is routed and mounted?
38,782 PostsLatest Activity: Sep 02, 2026
