StingrayL82
Jun 06, 2018Explorer II
DRTDEVL wrote:StingrayL82 wrote:
I have plenty of space all around, I’ll take some measurements and post later...I’m still in bed, and it’s 10AM....I’m sore as hell.
IIRC, the 8.00-16.5 was a 28.4” tire, so I’m about .8” taller, but I don’t remember how much wider I am. I went with factory Dodge and Ford dually steel wheels that I got from the tire shop down the road. Once I cut the locating pins off of the brake drums, the Ford duallys fit perfect.
How are you locating them on center? They are lug-centric coined wheels from the factory. That is why I went with a D350 donor, since it had 16 inch wheels, yet retained the coined pattern and locating pin setup.
The only thing those pins did was a line up both dual wheels, to ensure that the coins matched up. My new 16” wheels are still coined, so I just match the pinholes up. The only reason I cut the original pins, is because the Ford pinholes do not match up the way the Dodge pinholes do. Everything is still centered and works as it should
38,782 PostsLatest Activity: Sep 02, 2026
