my440
Jun 23, 2018Nomad
j-d wrote:my440 wrote:
Hi, hope you guys are all well, have not been here for abit. My 1978 Dodge Sportsman B300 440 ci. motorhome has a brake pedal that does not return. Need to pull it back with your toe to get the brake lights to turn off.
I removed the instrument cluster panel to access the pedal linkage area and lubed it up but to no avail.
Obviously there is not a spring to pull back the pedal that I see.
Any ideas? And the best way to troubleshot the cause so I can get the pedal to come back??
Thanks, really appreciate any assistance!
Brake pads drums calipers all new recently.
When we had a B300, we had that problem and traced it to the bellcrank that adapts the fore and aft push of the brake pedal, to the transverse booster/master cylinder assembly. I actually drilled it and tapped it for a grease fitting. Included lubing the bellcrank in my chassis lube routine.
Usually I edit a Quote down to only the item in question, but since you mention Instrument Panel, I remember the Instrument Cluster Ground was kinda goofy. It was a wire that ran down the firewall, under the floor mat, to a screw down by the floor. Not positive (sold the B300 in 1992. Might have been one of the two screws that held the Hi/Lo Headlight Button. Anyhow, make sure that connection is snug or your gauges will do odd things.
Oh yes the instrument cluster nightmare, that was last years task. I tracked that one down, regulator attatched to the back of panel lost ground. Oil, temp, fuel gauges quit. Good now tho,thanks, and for the lube tip. Still working on this...
38,782 PostsLatest Activity: Sep 02, 2026
