my440
Jun 23, 2018Nomad
Griff in Fairbanks wrote:my440 wrote:
Hi Giff, no talking about the rear brake lights in the back.
I'm going let StingrayL82 help you. I think he has fresher knowledge and I'm kinda jammed up right now, with a half dozen people begging for my attention.
In the case of the aforementioned #$@%#$% '90 Bronco, replacing the switch solved the problem. Age and repeated use cause the mounting bracket and internal mechanism to wear enough so I had to jam the pedal to floor to make the rear lights come on.
In your case, mechanism wear, in the pedal and switch mount, may be causing the pedal to sag or preventing the switch from turning the lights off.
As long as your brakes are working just fine, a light pedal return spring might solve the problem, at least until you can work out a better solution.
Giff thank you so much for your info and advice. Much appreciated. Motorhome driven back and forth to propane and sani dump. Will get it sorted sooner or later. May try a spring, temporarily .
38,782 PostsLatest Activity: Sep 02, 2026
