my440
Jun 29, 2019Nomad
Griff in Fairbanks wrote:my440 wrote:
Hi hoping everyone is doing ok.
Thought I should come by because I'm kindof stumped on whats going on with my 1977 Dodge B300 again.
Been having a brake pedal not returning problem for awhile and just now got to addressing the situation. Pulling back the pedal with my foot released the brakes no problem.
Today I installed a new master cylinder and brake booster and still brake pedal not returning.
I greased all the pedal linkage at an earlier date but never was the problem.
The front calipers are new as well as the rear drums with the whole brake kit was installed last year.
I have not bled the brakes yet as I run out of time and have not started it because battery was dead and had no cables.
So my question at this point is would not bleeding the brakes cause a non returning peddle? I'm doubting it but at a loss as to why no peddle is not returning still. I adjusted the booster rod to what I think is good several times but not in possession of the proper measuring device, I simply backed of the rod just a bit from where it contacted the master cylinder
Thanks
When was the last time the brake system was expertly flushed, refilled, and re-bled? (I'm guessing never ... and they should be flushed at least every 10 years, preferably every 5 years.)
Hi Griff
The system was flushed last fall and again today and bled after the install of new booster and master cylinder. All seems good now. Thanks
38,782 PostsLatest Activity: Aug 31, 2026
