Central_Scrutin
Aug 14, 2021Explorer II
WoW, I'm leaving this Progressive Dynamics "Charger" alone, it's pumpimg out @ 15 amps all by itself, so why "fix" it?
But the more important reason for this post is that I came up with a soft-latching circuit instead of using a mechanical relay solenoid that stays "ON" and draws from battery while on, draining it.
tap SW1 switch, power is then latched (like a mechanical toggle switch), press #SW2, powers now un-latched (off)
Trying to come up with a 1-button on/off circuit that will sense either battery's voltage drop and send converters charge circuit, or Alternator's charge if running/driving current to the appropriate battery... bare with me.... it's on the tu-du list
based off a ZF44 Mosfet transistor, and n o current draw from anything while "Latched"
.... trying to reduce to 1 button and a 555 timer chip instead of Mosfet....
~Whirled Peas
~Whirled Peas
38,782 PostsLatest Activity: Aug 11, 2021
