jschenzel
Jul 28, 2022Explorer
Did you ever locate a fuel sending unit? I have the exact same issue and am struggling locating one for my 1977 Shasta Dodge Sportsman 360.
Jason
Jason
Ashton1012 wrote:
Whats up everyone. I have a 1977 Dodge Sportsman RV with the 360. Bought her for 750$ and drove her to a friends house where it sat for a year. In august I finally had the money to fix her up for the roughly 500 mile drive home. So far shes had...
New tires (8.5 x 16.5) all around plus matching spare
Spark plugs, wires, distributor cap and rotor
Thermostat
Oil and filter
Radiator flushed and filled
Exhaust manifold gaskets
PCV valve
Air filter
Im sure im missing some stuff, i spent about two days working on her before I was confident to drive home.
Somethings Im currently working on;
Just replaced the fuel pump
Gas tank is currently out and has been cleaned. Ordering a new fuel sending unit and need to find a new tank bolt/plug then Ill reinstall the tank.
This Spring before I take her on some adventures;
Valve cover gaskets
Maybe the intake manifold gaskets, Still undetermined at this point. Once I get the valve covers and carburetor off Ill take a look to see if there are any leaks.
Carburetor rebuild
Transmission flush and filter replaced
The radiator has a small pinhole leak on the very top, easily accessible should be a quick fix.
Gauges do not work. I replaced the relay which cost me about 50$ (non returnable because it was an electronic part) and did not fix the problem. This stresses me out obviously as I don't know my operating temp or my oil pressure.
Exhaust needs to be replaced. There is a leak where the manifold attaches to the pipe, and the muffler has a bunch of holes drilled in it from the previous owner. I plan on replacing with dual exhaust, hopefully opening up a little bit of power.
Somethings I need help with!!
I cant find a matching fuel sending unit. Anyone know where to get one?
I have an issue with my drivers side duelly. The tires do not bolt on straight, and look extremely wobbly driving down the road. I took it back to the shop where they said they fixed the problem, about 45 minutes later another driver began flashing their brights until I pulled over, and they told me it is very apparent. By this time I was almost an hour away from the first shop, and had another 45 minute drive to the next. So I went to les schwab in the next city. Guy came out and tried to line them up, but said it would be impossible because my rims are supposed to have spacers and without them there is no way to line up the duelly. I do not believe that is the problem, because I had no issues before the new tires (same rims) were installed. I also dont have this issue on the passenger side, that does not have the spacers he was talking about either. I ended up driving the RV home and did not have issues, but Id rather not ruin my new tires this season so I need to address the issue. Anyone have advice?
Eventually Id like to rebuild the suspension, but I'm not sure where to look for parts. Do I just search for suspension parts for a B300?
Thank You!!
