Romer1
Sep 28, 2015Explorer
tinkerer wrote:
I have went from the ant-freeze method to the air clean out and won't be going back to the ant-freeze except for the drains. Go to a RV store and they have the adapter for adapting the air to your water system. I always leave one faucet open when pressurizing the system so I don't over pressurize the lines. I always go around the system twice to make sure all the water is purged. I generally start with the drains on the hot and cold water drains on my water system. I have had zero problems with water freezing, and don't have to put up with the anti-freeze in the lines.:)
X2, I leave compressor run for about 20 minutes with everything open, then I leave all faucets, drains, and shower open. That way any trace of water in lines will evaporate. Also leave water heater drain plug open.
