Empty_Nest__Soo
Sep 28, 2015Explorer
dodge guy wrote:
The problem with just blowing out the lines is that there is always a low point in one of the lines to trap water. No matter how much air you put through it, you will always have water left in a line somewhere. Do it right with RV antifreeze and you will have no worries. $6 worth of antifreeze is better than ripping apart a wall to try and find a ruptured line!
I believe your concern is entirely imaginary. I’ve been reading this forum and others for over 12 years and I have yet to hear of anyone who had ruptured pipes as a result of blowing out lines rather than using anti-freeze. Around here, people winterize cabins by draining and blowing out copper water lines.
Unlike copper or hard plastic, modern pex tubing used in RVs is flexible enough that it can freeze without bursting.
If pex fittings are full of water, they will probably rupture or the crimp will be pushed apart. Faucets, etc., will almost certainly freeze and burst if full of water. A little bit of residual water will do no harm because it is not under pressure to begin with and has room to expand.
If someone chooses to pump the pink stuff through their lines, that’s their choice. But don’t tell people that blowing out the lines doesn’t work or is risking burst lines.
Wayne
