Empty_Nest__Soo
Sep 29, 2015Explorer
et2 wrote:
My question is how does the red pop or air pressure feed back through the line coming from the water tank. I never have seen red pop feed back to the water tank. One would think water accumulates their. Unless the low point drain empties that line, which then would explain it.
When I blow the lines, I always run the pump for a minute after draining the tank and giving the lines a first blowout. Then I blow the lines a second time all around. I run the pump dry mainly to clear the pump of water, because I would expect the pump to crack if ice formed inside.
Wayne
