Effy
Sep 29, 2015Explorer II
et2 wrote:
My question is how does the red pop or air pressure feed back through the line coming from the water tank. I never have seen red pop feed back to the water tank. One would think water accumulates their. Unless the low point drain empties that line, which then would explain it.
To do the line from the water tank to the pump, I've put a half gallon in the gravity fill line into the fw tank and run the pump a second to pull it from the FW tank to the pump.
