Lantley
Sep 30, 2015Nomad
Empty Nest, Soon wrote:Lantley wrote:
I think both methods work if done properly. However anti freeze is foolproof with less chance for error and for the most part quicker.
To the guys that use the blowout method do you sanitize your water lines in the Spring?
Is the advantage to using the blowout method that there's simply no anti freeze to deal with? Is it the cost savings?
At the end of the day I want the most foolproof method.
To me, blowing out the lines seems perfectly foolproof, quicker and easier, and leaves no taste of chemicals from anti-freeze.
Wayne
I Imagine if this were true, The RV manufactures would use the blow out method exclusively and eliminate the expense of winterizing with anti freeze.
38,782 PostsLatest Activity: Sep 10, 2026
