My last TT was only 30 amp so I added a new 4 space panel (50 amp) and wired the existing panel to the new panel using a 30 amp breaker in the new panel. That made the factory panel a "sub panel". Then I moved the A/C from the old panel to the new panel and wired it up to a 20 amp breaker. I installed a new 50 amp power cord and connected the cable to a 50 (as a main) in the new panel.
I also added a outlet for and electric heater to the A/C breaker. I figured that nobody would ever run the heat and A/C at the same time.
I bought a 30 to 50 adapter so if I camped at a 30 amp only site, I could still plug in but only have 30 amps.
The TT used to trip the main at times but after the "upgrade" all those problems were solved.
I located the new panel where the power cord came into the TT and used the factory 10 gauge "hard" wire for the sub feed. Then ran a new 12 gauge wire (in plastic conduit) under the TT from the new panel to the A/C wiring (I had removed from the "sub") and connected it in a new junction box. Note: If you wanted to, you could use your old power cord for this if you cut the plug off. The wire is overkill but not by much and you already have it.
I un-bonded the sub and bonded the new panel.
I think a had a couple of hundred bucks in the upgrade. The wire was the most expensive item.
It's not a "true" 50 amp upgrade but it gets the "factory installed overload" off your 30 amp "maxed out" panel and really does away with a lot of problems.
The wife could dry her hair while I made coffee with the A/C on and the water heater running.
If you don't understand any of this, DON'T DO IT! LOL
