- mike_brezExplorer....and they look good too :R
- JimExplorerThere's another inexpensive and easy 'sway' fix that I used and really like. That's those plastic vortex jobs that stick to the back edge of the RV. I really like the handling improvements they made to my Journey.
Here's my write up of the installation and my thoughts about their performance while driving in all sorts of conditions: V-Spoilers - 10forty2ExplorerIs this your first experience driving a motorhome? If so, it may be your perception that is throwing you off. But yes, many of the Ford chassis RVs are prone to excessive sway, IMHO.
First and foremost, check the pressures in the tires against your actual loaded weight to make sure they are inflated according to the tire manufacturer's load chart.
If you're referring to body roll...feels top heavy, rolling from side to side....then verify that you have front and rear sway bars. If you don't, then you'll really want them. If you do, then you might benefit from the Cheap Handling Fix that can be readily found by doing a Google search for it by name. I would think that the unit is too young to have deteriorated sway bar bushings, but that is something to consider as well. Might want to consider upgrading the stock bushings to the poly bushings too.
If you're referring to what feels like the tail wagging side to side then you might benefit from a rear Track Bar that ties the body more securely to the chassis.
THere are several causes of "sway" so start with the easiest and work your way up from there.
38,756 PostsLatest Activity: Oct 31, 2025
