How old is the RV? If it is still under warrant, they might fix it. If not under warranty, then the 4-5 hours of shop time required to find and fix the leak, install fittings to recharge it, and add a couple of hours just in case it comes back in the first 90 days under warranty, then they could have bought a new unit for $700 and cost less.
I did fix a air conditioner for a buddy, and it did take me about 4 hours. I had to go home and get more tools, vacuum pump, torch, copper fittings, freon, and gauges, then come back, solder the leak, install the fittings, evacuate (that takes 1 hour, but you could be doing something else at that time, so normally the shops do not bill for that hour). Recharge with freon, and it was good to go.
If it is a older unit, normally they use R-22 freon. Brand new units, within about 3-4 years old, they would use R-410 Puron.
Good luck!
Fred.
